 GMC-300 Turns Off
Megatron Posted - 03/01/2012 : 07:32:27
I recently purchased the GMC-300 (FW 2.11) and have been monitoring for a couple days now. I have the driver and software loaded and have looked at the data. I'm looking forward to "real time" software monitoring.
Is it normal for the unit to turn itself off a few seconds after the data is downloaded to the computer?
Thanks for the support. I like the unit.
Megatron
ZLM Posted - 01/07/2013 : 10:43:57
Can you repeat it? if you can reproduce it easily, then it should be easily fixed.
bifferidge Posted - 01/07/2013 : 07:09:10
Originally posted by ZLM
The unit should not "itself off a few seconds ". I think that my be caused by the communication error after download.
Please make sure your used latest software. And select GMC-300 in the model field.
Just did a download of a few days-worth of data. Unit powered itself afterwards. Latest software, etc. A bug somewhere? Is there a workaround?
Megatron Posted - 03/02/2012 : 12:38:41
OK Thanks. I am using the latest software with the correct settings. Most of the time all appears fine. I have seen the symptom 3 times after downloading the data 9 times. I'll keep experimenting.
ZLM Posted - 03/02/2012 : 11:32:17
