 GMC-300 option for pulse output?
JP_Austin Posted - 06/26/2013 : 19:12:47
I am looking into networking my GMC-300 and found that the h**p://www.radiationnetwork.com/ offers some software that will work with pulse output type radiation detectors. The CPM-300 puts out an encoded data packet every second. Is there an option to make the CPM-300 output a pulse type output over the USB port? I realize that the unit has a USB to serial converter built in and I have been looking at the commands the unit supports. So far I tried to issue a
<GETVERS>>
I get back this: GMC-300Re 2.36
<HEARTBEAT0>>
As stated in the command format no response. The software then looking for the pulse output records zero pulses! That makes sense as I asked the unit to not transmit data every second.
What I am hoping for is a command to put the unit into the pulse per count mode. Can this be done?
delf Posted - 04/12/2015 : 18:25:56
Will, the TOOL-080 cable work with the RadiationNetwork's "GeigerGraph" program?
I discovered that the audio cable recommended for that app is looking for a 5V pulse and the GMC-320Plus only produces a -1V pulse.
Thanks,
Delf
ZLM Posted - 03/26/2014 : 09:21:42
Since Jan-2014, new model GMC-300E Plus and GMC-320 Plus come with standard analog data port. It outputs pulses for connection of third party software.
82.07 KB
TOOL-081 is able to convert this analog pulse into USB signal.
See:
http://www.gqelectronicsllc.com/comersus/store/comersus_viewItem.asp?idProduct=4544
JP_Austin Posted - 07/01/2013 : 19:00:56
The news is that the Radioactive@Home site is now able to read the GMC-300 and report the readings onto the BOINC map. See the link below. It's working fairly well now. The application properly reads the model number and version of firmware.
MAP
ht ://radioactiveathome.org/script/graph/drawweekdotted.php?hostid=7898
Site
To make the links work add the "tp" to the ht**
JP_Austin Posted - 07/01/2013 : 07:53:05
Yes I understood that. I was asking if a new function could be implemented in a new version of the firmware to support a pulse output through the USB interface. I am not exactly sure how that would be carried out since the USB only acts as a RS232 to USB conversion. A pulse output would not really comply to any recognized communication format for USB or RS232. Most of these other sensors put out a logic high per count. If the format of the data were structured to only provide a single pulse per count that would essentially provide the function. Something to consider.
ZLM Posted - 06/28/2013 : 13:35:19
The < HEARTBEAT0 >> command is to stop sending data from GMC-300.
The < HEARTBEAT1 >> command is to start sending data from GMC-300.
JP_Austin Posted - 06/28/2013 : 07:14:19
I guess the answer is no. I will not get the Radiationnetwork software then.
I did get the unit to communicate on a world map for free by going to Radiation@Home and following the instructions on the forum. It's now live. h**p://radioactiveathome.org/map/
