 Firmware versions...
WigglePig Posted - 07/21/2021 : 06:01:50
Good day!
Can anyone indicate what the latest firmware version numbers are please? I am specifically interested in the 500+ firmware.
Regards
Piggly
cvee Posted - 07/21/2023 : 18:00:17
Hi cvee, please email support@gqelectronicsllc.com if you havent gotten any reply back.
Sent via email.
EmfDev Posted - 07/21/2023 : 16:35:54
cvee Posted - 07/21/2023 : 16:09:21
I sent a message via here, but not heard anything back.
How long does it usually take?
I only ask, because previously it seems messages send via the website weren't going through.
ihab17 Posted - 07/16/2023 : 23:54:27
Originally posted by Grün-2650
Hallo,
Habe seit ein paar Wochen einen GQ GMC 500+ mit der Firmware 2.45 gibt es eine neuere ?
Meine Serien-Nr. 5D EC 48 4C 31 36
36 16 47 38 36 34
Bin dabei das Gerät aus zu testen, bin bisher sehr zufrieden damit.
Danke im voraus für Info und Unterstützung hier.
In order to get the latest firmware, you have to mail the support with your serial number you mentioned above
ihab17 Posted - 07/16/2023 : 23:50:36
Originally posted by Senketsu
I received the package, each of the five dosimeters has Re 2.29 and it looks like it was the latest version. Besides, every GM M4011 meter is painted black
If you were told to throw away all your Geiger counters/dosimeters and keep only one of them, which one would you keep?
Grün-2650 Posted - 07/14/2023 : 22:42:09
Hallo,
36 16 47 38 36 34
Senketsu Posted - 04/28/2022 : 23:17:38
Senketsu Posted - 04/28/2022 : 15:29:36
I will not create a new topic, so I will write here because I have a question. I bought 5 additional GMC-500 dosimeter. What's the latest firmware for them?
svalex Posted - 09/29/2021 : 23:56:23
By default the data is being sent to the GMCMAP. Make sure you enter the correct Geiger Counter ID and User ID.
Thanks a lot. Now it works.
EmfDev Posted - 09/29/2021 : 09:54:41
svalex Posted - 09/29/2021 : 01:59:49
Originally posted by svalex
Oh yes, this works - thanks for it.
Although I hope the firmware of the device would show avalable SSIDs to choose instead of troublesome entering in a next version.
Or is there another firmware instead 2.24 ?
Now when I'm connected to my WLAN I receive the message "Wifi Date Send Failed" on the device. But Ido not know, where this data are sent to?
How can I use the Wifi connection now?
svalex Posted - 09/29/2021 : 00:42:59
Hi svalex, there is a way to use PC. Download the GQ Data Viewer software, http://www.gqelectronicsllc.com/downloads/download.asp?DownloadID=61
Then go to Settings -> Others -> Read form device -> Input WiFi parameters -> Write to device.
Or Settings -> Configuration -> Read from device -> Input WiFi parameter -> Write to device.
You can also use the Data Viewer software to send the wifi data online instead of the WiFi feature from the GMC device.
EmfDev Posted - 09/28/2021 : 10:20:24
svalex Posted - 09/28/2021 : 01:09:21
It's so difficult to setup WiFi connection with the device. Is there a possibility to do by USB with PC/Windows ?
svalex Posted - 09/28/2021 : 01:06:52
Is there another firmware than Re 2.24 for GMC-500+ ?
My serial 381533383733BD
EmfDev Posted - 07/21/2021 : 10:43:28
Hi Piggly, can you please send me your serial number? I can check the latest firmware revision for your device.
