Author |
Topic  |
engelbert
Netherlands
14 Posts |
Posted - 03/20/2022 : 03:38:45
I have install Geigerlog from Ullix and have some truble. i get a mistake: -------------------- d@-Satellite-L350:~$ './geigerlog' Traceback (most recent call last): File "./geigerlog", line 91, in <module> from gsup_utils import * # includes import of gglobs File "./geigerlog/gsup_utils.py", line 76, in <module> import sounddevice as sd # sound output input File "/home/hd/.local/lib/python3.8/site-packages/sounddevice.py", line 71, in <module> raise OSError('PortAudio library not found') OSError: PortAudio library not found ------------------- The solution is install sounddevice by this instruction: sudo apt-get install libportaudio2 |
https://weerstationbijdetoren.nl |
1196 Posts |
Posted - 03/21/2022 : 00:05:42
I am not sure I understand: are you just reporting an error, or are you already including the solution?
If you still have the question, I would need more details on the problem, like type of OS (looks like Linux), versions. Best is to start GeigerLog with: 'geigerlog -dvwR' and provide to me the resulting 'geigerlog.stdlog' file (find it in the data directory). You can use the GeigerLog sourceforge site under "Discussion" to post this file (https://sourceforge.net/p/geigerlog/discussion/ )
engelbert
Netherlands
14 Posts |
Posted - 03/22/2022 : 06:06:14
@ullix, No i just trying to help.
But i have another question. I have succesfully installed the geigerlog software (thanks for that). i don't understand how i contect it to my laptop Do i need a usb-serial cable or can i use wifi. usb-audio cable is connected (the audio button is green, GMC button is red) . and when i use wifi what are the settings
Thans in advance. |
1196 Posts |
Posted - 03/23/2022 : 01:41:02
I am bit at a loss to understand what is going on with your setup. First you say you get the OS-error, then you seem to suggest a solution, now you say, no, you didn't, but then you are running GeigerLog anyway, which is only possible when you did overcome the error? Which is it?
If you were able to find a correction, then I'd like to know what the problem and the solution was, because I'd either fix it in the code, if it is a bug in GeigerLog (doesn't look like it) or can advise users on what to do if the problem is elsewhere.
Regarding connecting and running: please, see the manual in the chapter about the GMC counters.
WiFi is possible, however, due to a bug and deficiency in the firmware of the counter, it is not trivial to do. You need to install, run and modify an Apache server and install some php software. Again, it is all in the manual in sufficient detail to replicate, chapter "WiFi Devices managed by GeigerLog".
An easier way would actually be to ignore the build-in WiFi of your GMC-320 counter and use a Raspi as a "converter", see this post: "WiFi Enabling a GMC-300E+ Counter" http://www.gqelectronicsllc.com/forum/topic.asp?TOPIC_ID=9836
220 Posts |
Posted - 11/04/2023 : 02:56:15
Thans in advance.
To use GeigerLog, your device must be connected using the USB cable to your laptop. GeigerLog cannot use Wifi to connect to the device and work as GeigerLog is implemented. |
1196 Posts |
Posted - 11/05/2023 : 00:27:04
@victorpatrick:
I don't understand. GeigerLog should be running on your laptop. Why do you think about connecting to it?
Assuming that you have a GMC counter, you connect this one with your laptop with the USB cable supplied with the purchase of this counter.
And while you can use the audio adapter, it does not make sense when you have a GMC counter. Just the USB cable is needed.
In GeigerLog's configuration file solely activate the GMC counter and start GeigerLog. See the manual for more help.
2322 Posts |
Posted - 11/06/2023 : 14:49:27
@victorpatrick is a spam account. |
Topic  |
