 S.S. Bimetal Thermometer Back Mount, With Sliding
Sebahtstian Posted - 04/09/2017 : 23:19:14
Details
S.S. BIMETAL THERMOMETER BACK MOUNT (WITH SLIDING CONNECTION)
MODEL: TEF
HS CODE: 902519
Application:
stainless steel bimetal thermometer developed specially for covered HVAC applications outside or where the environment is wet or damp. The stainless steel case and bezel will offer excellent resistance against corrosion but the instrument should not be directly exposed to rain or splashing water. For applications outside where the instrument will be fully exposed to the elements
SPECIFICATIONS
Nominal size (mm):#216;63 mm (2.5Ħħ); #216;75 mm (3.0Ħħ);#216;100 mm (4.0Ħħ);#216;160 mm (6Ħħ);
Scale ranges: -40+60 0C to 0-600 0C
Accuracy class: 1.6,1.0
Design: Stem with thread
Stem diameter(mm): 6, or optional
Wetted parts: Stanless steel
Connection: Center Back.1/2"
Case material: Stainless steel, bayonet type
Window: Glass
s.s liquid filled pressure gauge
din quality pressure gauge
hot water thermometer
