 help for emf zero model 390
tartaria70 Posted - 08/23/2022 : 12:10:45
please the emf zero settings is missing on the emf 390.
how to set the device ?
I need set to zero inside anti radiation material.
thank you
gpapnet Posted - 02/27/2024 : 08:03:22
To set the EMF 390 to zero inside anti-radiation material, you'll need to calibrate the device. Check the settings menu for calibration or baseline options, then follow the instructions in the manual. If there isn't a specific "EMF zero" setting, look for similar options to reset the readings.
EmfDev Posted - 02/16/2024 : 12:47:28
Hi mmilla, do a factory reset by going to Main Menu -> Init Setup -> Factory Reset -> Yes -> wait.
mmilla Posted - 02/15/2024 : 11:12:50
I have a GQ EMF-390v2 Re.372 too. Lately it seems to me that the device does not make correct readings.
How can I recalibrate it?
Thanks.
EmfDev Posted - 10/04/2022 : 14:41:11
hi tartaria70, you have to email support@gqelectronicsllc.com or me with your serial number to check if there is a firmware update for your device.
tartaria70 Posted - 10/03/2022 : 15:41:09
if ever where can i download the thing + flash guide.
thank you.
EmfDev Posted - 09/19/2022 : 09:18:47
yes mg is milligauss. it can zero out specific range of emf. I will forward it to support to check if they can add it back.
tartaria70 Posted - 09/13/2022 : 10:57:14
mg is milligauss ? does this will help zeroing the device inside
a radiation tissu please?
In fact i lack the knowledge to undestand this setting .
i think zero-mf was more simple since you just hit the button
then it setup the thing in a zero radiation environnement.
EmfDev Posted - 09/08/2022 : 12:40:10
You can set up a range e.g. 0-5mG and then set the factor to 0% so the result from the 0-5mG will read 0mG.
tartaria70 Posted - 09/08/2022 : 05:15:21
ah yeah but what does "add range" is and can be set up ?
EmfDev Posted - 09/06/2022 : 15:16:55
it is under Main Menu -> Init Setup -> EMF Factor
tartaria70 Posted - 09/06/2022 : 12:49:22
@EmfDev there is no settings named emf factor.
tartaria70 Posted - 09/01/2022 : 10:42:58
thanks for your response.
can you tell me how to do ?
EmfDev Posted - 08/29/2022 : 14:01:12
Hi tartaria70 it is removed and replaced with EMF Factor.
tartaria70 Posted - 08/29/2022 : 04:45:15
revision is 3.69 model 390v2
