 A few firmware feature suggestions for GMC-3150
cloud Posted - 06/29/2022 : 21:45:34
After playing around with the counter for a week, I feel that 2 things can definitely be improved:
1. missing a text mode like 600+;
2. swivel should not override "movement detection".
Another thing is the dosimeter mode's threshold can't easily be adjusted by pressing the buttons and I didn't find a command that changes this setting from the serial terminal. If there's indeed no such a command, then:
3. missing a serial command to change dosimeter warning threshold and / or toggle only this warning.
If you don't want to add a text mode, then at least allow users to mute the dosage warning independently.
I know pancake GM tubes are not energy compensated, but a feature is a feature.
By the way, what does that +-5% accuracy refer to?
EmfDev Posted - 07/06/2022 : 10:02:20
Hi cloud, thank you for your feedback. Text mode has been removed for the GMC-3150. We will check the #2 and #3. The +- 5% accuracy is based on the estimate time.
@shawn_wang, yes.
shawn_wang Posted - 07/05/2022 : 22:12:53
Is GMC-3150 the chinese version of 600+?
And is GMC-1130 the chinese version of 320V4?
