 Logging from GMC320+ V5 /Wifi to server.
JT Posted - 08/18/2019 : 06:49:16
Logging to server via WiFi connection
I have a problem - I am connecting to wifi ok. "Test server connection" does not return a confirmation nor error. Website set to www.gmcmap.com, url is log2.asp. I have a registration id and geiger id. Auto update is failing from the unit.
I am registered with both user ID and Geiger counter ID on the website. (Everything ok via PC gq gmc data viewer) but not via Wifi ?
Help appreciated
GMC320 plus V5, Rev:5.12
23   L A T E S T    R E P L I E S    (Newest First)
Geo-Johnny Posted - 08/20/2019 : 12:56:10
Thanks Geo-Johnny for helping :)
No problem, you're welcome. We need to stick together, whether in America or Europe, because we could all be victims of a failed nuclear policy.
JT Posted - 08/20/2019 : 11:58:53
Yes thank you. Yes it is a strange mistake, because on the web id there is still a zero in front of the ID number, and as you said, you can use a zero in ID. and it works. Yes it is strange. But, the most important thing now is that it works. Now I can assist other users IF they should experience the same error as i did.
EmfDev Posted - 08/20/2019 : 11:55:38
Geo-Johnny Posted - 08/20/2019 : 11:41:31
Now you have a lot of fun with your GMC320+ V5. Congratulations on my part and welcome to the club.
Geo-Johnny Posted - 08/20/2019 : 11:35:24
The work was not in vain, you learn a lot with such simple mistakes. But it is very mystical the whole story, because I have entered the leading zero on both my devices and it runs without problems. Typing mistakes can make life really hard for you, it is often to despair.
JT Posted - 08/20/2019 : 11:33:58
... and now its also logging OK via my router. GREAT !
Imagine it was just a "zero digit" that messed it all up.
JT Posted - 08/20/2019 : 11:22:25
I just removed the "0" as yout told me til try, and no i got "SUCCESSFUL" wow ! :-) now its logging via Hotspot, i will next try via my router/modem network. (I did not had to re-register a new account).
Thank you very much for your help both of you, I had hardly figured this out myself.
EmfDev Posted - 08/20/2019 : 10:14:17
Yes the 0 in the beginning might try to remove it. Also maybe try to reregister a new geiger counter on the website and delete the current one.
Geo-Johnny Posted - 08/20/2019 : 10:11:33
Good to know that there is a new firmware.
But in the history with the server login I know no more advice. Maybe it's just a typo in the User- or Counter ID? Example 0 or O
JT Posted - 08/20/2019 : 09:48:42
I have now set up and activated a hotspot on my mobile phone. Added the new SSID and new password from mobile on to the GMC-320plus V5 now v5.52. Test: "WiFi contact perfect".
But when I test server I get exactly the same as with modem / router connection. "Does not return a confirmation nor error".
Strange.
But then i suppose I can conclude that there is NOT something wrong / blocking on the router / modem since I achieve the same result via HotSpot.
Geo-Johnny Posted - 08/19/2019 : 22:54:24
If the URL can not be resolved, this can have several causes. Either a wrong DNS server is registered in the router or a firewall is running for some clients. I do not know what is allowed by your provider to change something on the router? If it does not work with the GQ Worldmap Server IP, a firewall can be the problem.
If it works via the mobile hotspot of a smartphone, or via another Wi-Fi network, for example, neighbor or friend, then the problem is clearly on your router. If it does not work over another WLAN, the error lies with the GMC.
JT Posted - 08/19/2019 : 14:59:56
"Geo Johnny" - Yes i agree - it looks like a routing problem.
Please explain " Or the DNS name is not resolved" Is there anything i can check in admin router ?
"EmfDev" Yes i will report
EmfDev Posted - 08/19/2019 : 14:51:47
Ok let us know if something happens.
Also does it say Connected after connecting to WiFi?
JT Posted - 08/19/2019 : 14:50:23
"Geo-Johnny". Tried to enter the IP address. No change. I will now try the hotspot via mobile.
"Emfdev". Yes I will now try to set up a hotspot via mobile phone.
I have tried to enter data both directly to the GMC-320 and via the data viewer with the same result.
Thank you for helping me solve this problem.
EmfDev Posted - 08/19/2019 : 14:30:44
Did you write the parameters using the data viewer?
Yea try Geo-Johnny's suggestion to use a another WiFi to check.
Geo-Johnny Posted - 08/19/2019 : 13:40:56
For me, this still looks like a routing problem. Or the DNS name is not resolved.
1) You can try instead of the server web address www.gmcmap.com the IP 184.168.224.226 to enter. If it works then the DNS name is not resolved from the GMC.
2) If you have a smartphone, you can turn on a Wi-Fi hotspot and connect the GMC via this hotspot. If it works, the problem is with the router.
Hmmm, Remote diagnostics are always a bit difficult to create.
JT Posted - 08/19/2019 : 13:10:28
Hi JT, can you check how many minutes did you set your period? Test connection succeeded correct?
Hi
Period is set to 1.
It's just fade out when the display backlight goes off.
EmfDev Posted - 08/19/2019 : 09:19:01
JT Posted - 08/18/2019 : 14:51:29
Originally posted by JT
Originally posted by Geo-Johnny
Hmmm, 10.0.0.99 looks good. Then the router gateway should be in this IP range 10.0.0.xxx with the subnetmask 255.255.255.0
At the moment I do not know anymore. Maybe a factory reset of the GMC will help.
Yes, that's correct. I need to log in via 10.0.0.xxx to my telecom provider to manage devices etc. I can see there that gmc-320 is registered ok on lan. It's probably something that blocks me from getting out. I know too little about exactly this so I get to inquire a bit with this. Thanks for your help so far.
Did a factory reset of the gmc-320, unfortunately it did not help. All suggestions are welcome
JT Posted - 08/18/2019 : 13:01:43
Geo-Johnny Posted - 08/18/2019 : 12:10:14
JT Posted - 08/18/2019 : 10:46:27
It looks like a router Problem. Wich IP get your GMC?
It could be. IP 10.0.0.99
Geo-Johnny Posted - 08/18/2019 : 08:56:50
