 GMC200 to 1-wire
rwcherry Posted - 12/02/2014 : 08:18:11
Has anyone interfaced the data output of the GMC200 to a 1-wire counter like the DS2423. It looks like the GMC200 only outputs 1.4V pulses and the DS2423 is looking for > 2.4V??
If anyone has done it, please share; otherwise I'll go ahead and do it.
ZLM Posted - 12/02/2014 : 11:07:23
The GMC-200 uses two diodes to clamp the audio output level to 1.4V. The original signal voltage is 9V.
You can remove two diodes and place a zener diode instead.
See:
http://www.gqelectronicsllc.com/forum/topic.asp?TOPIC_ID=3407&SearchTerms=diodes
