 GMC-800 terminal interface
bmomjian Posted - 03/20/2024 : 11:01:27
I was able to successfully connect to the GMC-800 using the Linux terminal interface 'cu'. I used the command:
cu --nostop -l /dev/ttyUSB3 -s 115200 dir
The "--nostop" is needed so binary data coming from the GMC-800 is not interpreted as xon/xoff flow control commands. You might also need to set 'raw' mode using stty.
I used speed 115200, and the commands listed in this forum at:
https://www.gqelectronicsllc.com/forum/topic.asp?TOPIC_ID=10394
I am specifically using "<GETCPM>>". The AT commands did not work for me.
bmomjian Posted - 03/30/2024 : 03:42:59
The API for the GMC-800 is at http://www.gqelectronicsllc.com/download/GQ-RFC1801.txt
bmomjian Posted - 03/27/2024 : 16:28:34
I think you would be better off coding in Python. Code as simple as your current is e.g : "geigerlog_simple.py"
you find here: https://sourceforge.net/projects/geigerlog/files/
There are some nuanced increases in complexity in files on the same site.
Pre-releases of developments are: https://sourceforge.net/p/geigerlog/discussion/devel/
Looks interesting, though on the GMC-800 the CPM is four bytes, so the script would need modification. Fortunately my script is working.
ullix Posted - 03/27/2024 : 09:26:57
bmomjian Posted - 03/26/2024 : 06:47:36
AT commands are not supported on hte GMC-800. It does not have WiFi feature.
Ah, good to know about AT not being supported.
I ended up realizing that 'cu' was overkill for my purposes so I went with a simpler Linux shell script. It just sends the command to the device and gets the reply. I found that each time I reconnect the USB cable to the device, I have to send ">>" to get the connection established; if I don't the first command I send is ignored:
# connected?
[ ! -e /dev/"$GEIGER" ] && exit 1
stty -F /dev/"$GEIGER" raw 115200
# Was tty reconnected?  Reset so we get a reading on the second try.
if ! stty -F /dev/"$GEIGER" | grep -q 'rprnt = ^K'
then    # send dummy command
        echo -n '>>' > /dev/"$GEIGER"
        # set a dummy settings so we can detect reconnection
        stty -F /dev/"$GEIGER" rprnt '^K'
fi
CPM=$(perl << 'END'
        use strict;
        use warnings;
        use Momjian_us;
        # could hang, allow two seconds for read
        # https://unix.stackexchange.com/questions/559235/read-stdin-with-timeout
        local $SIG{ALRM} = sub { exit(1) };
        alarm(2);
        my $device = "/dev/$ENV{GEIGER}";
        open(my $geiger, '+<', $device) or
          sysdie("cannot open $device");
        print({$geiger} '<GETCPM>>');
        sysdie("cannot read four bytes from $device")
          if (read($geiger, my $byte4, 4) != 4);
        # Network/big endian ordering 4-byte integer
        # Newer models use 4-byte CPM for the GMC-500+, not 2
        # https://www.gqelectronicsllc.com/forum/topic.asp?TOPIC_ID=10394
        # https://www.gqelectronicsllc.com/forum/topic.asp?TOPIC_ID=9682
        print unpack('N', $byte4) . "\n";
        alarm 0;
END
echo "$CPM"
EmfDev Posted - 03/21/2024 : 09:42:31
