 change the year
mserdag Posted - 08/08/2023 : 05:03:44
Hi , i try to set de year using <SETDATEYY[D0]>>, D0 = 17 (YEAR 2023), but when i read using <GETDATETIME>>, the year hasn't updated, what is wrong?
I can turn on <POWERON>> and turn off <POWEROFF>>, get serial <GETSERIAL>>, but not update the year.
EmfDev Posted - 08/09/2023 : 10:30:37
I just tested it with EMFPRO terminal with SETDATEYY and 0x17 for D0 and works. is your D0 in ascii?
mserdag Posted - 08/08/2023 : 12:30:26
i can get date and time, but i can't set, by software, i can do it manually, the device is a EMF-390, i follow the instruccions of the manual, but i have doing some wrong, i don't know what.
EmfDev Posted - 08/08/2023 : 10:31:43
Hi mserdag, are you able to set it manually on the device? what model do you have?
