 URL for logging
balthus Posted - 02/27/2021 : 02:21:38
I'm trying to use my own logging system on my network.
I plan to run a small python script to listen on a port for logging requests and send them into influxdb.
However, when specifying the url there is no way to enter ':'
what should we specify if we want to send request to h**p://192.168.1.250:5555
The 5555 is the port and we need a : to specify it.
Can it only send request to port 80 (or 443).
Does the server has to be ssl or can it be without encryption?
Best regards,
ps:I just received a firmware update (2.19-> latest) but haven't installed it yet as it's windows executable and need to find back some old windows to set it up. Maybe that firmware contains the missing : but still not sure about the http/https
mojo66 Posted - 07/19/2021 : 16:16:53
Has anyone managed to set a custom port?
ihab17 Posted - 03/01/2021 : 08:36:16
You can use GeigerLog as Ullix stated or you can use the software provided by GQ
Download the latest version of GQGMCDataViewerV2.62.exe and that would solve your issue.
https://www.gqelectronicsllc.com/fw/GQGMCDataViewerV2.62.exe
From this software that runs on Windows you can do everything.
ullix Posted - 02/27/2021 : 02:53:43
If the matter is only to enter a certain character, then this can be done with GeigerLog.
Whether the counter would honor the specification of a port is a different matter.
