 GMC-320 Screen restart every 5 seconds
remib Posted - 04/14/2015 : 16:40:07
Hi
The detector seem to work i hear the sound in background
But the startup screen restart every 5 seconds.
all i see is GMC-320 +v4
and I can't shutdown unless i remove battery.
ZLM Posted - 08/02/2015 : 17:26:49
One customer is able to recovered the unit by sending a FactoryRest command via Data Viewer software during the re-booting.
In that case the problem is caused by incorrect configuration data. The Factory Reset command restore the good default configuration data back.
ZLM Posted - 04/19/2015 : 09:22:09
This is a hardware problem.
You may need to contact support@gqelectronicsllc.com for the warranty replacement. You need to include your order number and purchase references.
