 Set potetiometer for LND712
ska Posted - 10/03/2012 : 05:12:26
Hi
I can't set voltage directly, so I need to know in which resistance I sould set the potentiometer to have 500V?
ZLM Posted - 10/07/2012 : 10:53:38
You need to check the voltage by a regular 11M ohm internal resistance multimeter. Serial a 1G ohm resistor on your multimeter prob. Read the voltage frm the multimeter with 20V range.
And then calculate the actual voltage by following formular:
V(actual) = V(DMM read) x ((R(meter) + R(probe)) / R(meter))
Here:
Voltage = V(reading from multimeter) * 91.9
if your multimeter reading is 4.2V, then the actual voltage is 4.2*91.1 = 382.62V
