 Displaying Inconsistent Readings
nolanmaris Posted - 08/28/2024 : 00:38:34
Hi everyone,
I am having trouble with my GQ Geiger Muller Counter. It seems to be displaying inconsistent readings that fluctuate wildly even in stable environments.
Model: GQ GMC-300E
The counter shows highly variable readings when exposed to a stable radiation source. For example; when testing in an area with a known low radiation level; the readings bounce between very high and very low values without any apparent reason.
I have tried recalibrating the device and checking the connections; but the problem still there .
The issue began after I updated the firmware. The counter appears to function normally otherwise; with accurate readings when tested against known sources of radiation. I have checked https://www.gqelectronicsllc.com/forum/topic.asp?TOPIC_ID=9525
Has anyone faced similar issues / have any suggestions for troubleshooting this problem?
Any help would be greatly appreciated.
Thanks in advance!
nolanmsbi
EmfDev Posted - 08/29/2024 : 10:43:15
You can send your device serial number to support@gqelectronicsllc.com to check for an update.
Kaninbjerget Posted - 08/28/2024 : 12:56:28
Sounds exactly like the main issue I had with GMC-800 (check that thread). A firmware update solved that.
