 What append if....
Gallaxial Posted - 07/21/2020 : 11:59:23
Model: GMC-320 Plus , This Hardware have a DATA LOGGER
The Map Website look to be Static , What append if i Move around my City
Does the WiFi Connection Update the Website when Come Back At Home ?
or i have to do Manually ?
GBG12 Posted - 08/13/2020 : 18:57:52
The only mapping website I know of that can show geographic tracks like that is Safecast https://safecast.org/tilemap/?y=46.3&x=-105.2&z=5&l=11&m=3 with the 'Safecast Points' layer turned on. It shows single readings along a travelled route defined by GPS data. Some of their data submitters use GMC devices with GPS receivers. Those tracks are not suited to changing conditions over time, but are more for stable variations by location like Uranium mines or spill sites.
Gallaxial Posted - 08/11/2020 : 13:10:50
Originally posted by Gallaxial
-I was thinking to write the Same Wifi name/password in my hotspot cell
want go out with my cell i can activate the hotspot and the GMC-320+ can Continue
to Update the Webpage and the GPS of the GNC-320 Will do the Rest
-update the Webpage Every x Minute (5-30)
i will try this when i have time !
I find that the Device Does not have a GPS
it update the home only
Gallaxial Posted - 08/11/2020 : 09:10:59
GBG12 Posted - 07/26/2020 : 09:37:10
EmfDev's amswer is good if you move the detector to a single new location and want to record some history at that new location under a new map pin. If the connection is lost (e.g. detector out of WiFi range, WiFi down, etc.) and later restored, I don't think the map server uploads old missing data values from the detector's internal memory. There is just a gap in the map data.
EmfDev Posted - 07/21/2020 : 14:58:30
You have to manage geiger coutner from gmcmap and add another geiger counter and then copy the geiger counter ID to your device.
