 How to remove and then solder a SMD chip on PCB?
ZLM Posted - 02/13/2012 : 17:12:07
The steps to remove and then solder back a SMD chip. Following tools are used:
1. a 2-in1 rework station (TOOL-021)
http://www.gqelectronicsllc.com/comersus/store/comersus_viewItem.asp?idProduct=4393
2. SMD rework essential pack (TOOL-031)
http://www.gqelectronicsllc.com/comersus/store/comersus_viewItem.asp?idProduct=4446"
Remove Steps:
1. Prepar the SMD rework station
Adjust temperature to 350 degree C on both hot air and iron.
2. Use hot air to heat the chip and remove the chip using the tweezer.
3. Chip removed
[b]4. Plcae the chip in adapter for read/write on programmer
jbdavi211 Posted - 12/15/2019 : 18:17:46
Hello, if you want some in depth info and video of how to do all the things asked in this forum , rework, solder, R&R chips
look at a guy in NY that repairs MAC boards as he has all sorts of FREE videos on how to R&R chips and how to protect other chips on the board next to what your doing.
No I don't know this guy but watch lots of his videos as he really explains how to do chip and board repair RIGHT
he has lots of youtube videos for all that sort of stuff, just search on youtube
>>> Louis Rossmann <<<
Betty Hunt Posted - 06/25/2019 : 05:18:39
You are using the right way ElsaCline.
Betty Hunt Posted - 05/29/2019 : 04:33:21
You can go upto 380C-400C.
radciffkaty1 Posted - 04/04/2018 : 04:59:51
Hello @ZLM
While using hot air to desolder the SMD components, What temperature is reasonably safe?
ZLM Posted - 08/01/2015 : 17:05:56
The iron is going to be used when soldering back the chip.
rddube Posted - 07/31/2015 : 11:23:41
I have a question: Why turn on the iron if it is not used?
Thank you!
Raymond
Generated in 0.12 sec. Snitz Forums 2000
