 Software Trouble with GMC-600
ullix Posted - 04/20/2024 : 21:50:39
Like before in the GMC-800 case (http://www.gqelectronicsllc.com/forum/topic.asp?TOPIC_ID=10394) it seems that firmware 2.52 for the GMC-600 is using a configuration memory with settings quite different from both the old 600 and the new 800 configurations? Quite unfortunate.
@EmfDev, could you please post the actual configuration definitions for 2.52 on a GMC-600?
And from which firmware version onward is this valid?
ullix Posted - 04/24/2024 : 04:14:44
Thanks!
This is now included in the latest pre-release pre78, which you find here: https://sourceforge.net/p/geigerlog/discussion/devel/
Should reflect both GMC-500 and GMC-600.
EmfDev Posted - 04/23/2024 : 09:40:08
For 500/600/+
6 point calibration is added with 2.44 rev.
500 and 600 shared the same config since 2.31
500+ new calibration has 6 points. 3 for tube 1, 3 for tube 2.
old 3 point calibration addresses are not used anymore.
PowerOnOff,
AlarmOnOff,
SpeakerOnOff,
IdleDisplayMode,
BackLightTimeoutSeconds,
IdleTitleDisplayMode,
AlarmCPMValueHiByte,
AlarmCPMValueLoByte,
CalibrationCPMHiByte_0,
CalibrationCPMLoByte_0,
CalibrationuSvUcByte3_0,
CalibrationuSvUcByte2_0,
CalibrationuSvUcByte1_0,
CalibrationuSvUcByte0_0,
CalibrationCPMHiByte_1,
CalibrationCPMLoByte_1,
CalibrationuSvUcByte3_1,
CalibrationuSvUcByte2_1,
CalibrationuSvUcByte1_1,
CalibrationuSvUcByte0_1,
CalibrationCPMHiByte_2,
CalibrationCPMLoByte_2,
CalibrationuSvUcByte3_2,
CalibrationuSvUcByte2_2,
CalibrationuSvUcByte1_2,
CalibrationuSvUcByte0_2,
IdleTextState,
AlarmValueuSvByte3,
AlarmValueuSvByte2,
AlarmValueuSvByte1,
AlarmValueuSvByte0,
AlarmType,
SaveDataType,
SwivelDisplay,
ZoomByte3,
ZoomByte2,
ZoomByte1,
ZoomByte0,
SPI_DataSaveAddress2,
SPI_DataSaveAddress1,
SPI_DataSaveAddress0,
SPI_DataReadAddress2,
SPI_DataReadAddress1,
SPI_DataReadAddress0,
nPowerSavingMode,
nSensitivityMode,
nCOUNTER_DELAY_HiByte,
nCOUNTER_DELAY_LoByte,
nDisplayContrast,
MAX_CPM_HIBYTE,
MAX_CPM_LOBYTE,
nSensitivityAutoModeThreshold,
nLargeFontMode,
nLCDBackLightLevel,
nReverseDisplayMode,
nMotionDetect,
bBatteryType,
nBaudRate,
nCPMSpeakerOnOffCalib,
nGraphicDrawingMode,
nLEDOnOff,
nHCPMCAL,
nSaveThresholdValueuSv_m_nCPM_HIBYTE,
nSaveThresholdValueuSv_m_nCPM_LOBYTE,
nSaveThresholdMode,
nSaveThresholdValue3,
nSaveThresholdValue2,
nSaveThresholdValue1,
nSaveThresholdValue0,
SSID_0,
SSID_63 = SSID_0 + 63,
Password_0,
Password_63 = Password_0 + 63,
Website_0,
Website_31 = Website_0 + 31,
URL_0,
URL_31 = URL_0 + 31,
UserID_0,
UserID_31 = UserID_0 + 31,
CounterID_0,
CounterID_31 = CounterID_0 + 31,
Period,
WIFIONOFF,
TEXT_STATUS_MODE,
FAST_ESTIMATE_TIME,
THIRD_PARTY_OUTPUT, //for sending 0xFF per count via serial. This data format used on NETC.com software
HIGH_VOLTAGE_LEVEL_TUBE1, // for adjusting tube 1 voltage
HIGH_VOLTAGE_LEVEL_TUBE2, // for adjusting tube2 voltage
CPM_TUBE_MODE,
CPM_TUBE_DISPLAY,
VOLTAGE_DISPLAY,
DEADTIME_ENABLE,
DEADTIME_TUBE1_HIBYTE,
DEADTIME_TUBE1_LOWBYTE,
DEADTIME_TUBE2_HIBYTE,
DEADTIME_TUBE2_LOWBYTE,
MEDIUMTHRESHOLD_HB,
MEDIUMTHRESHOLD_LB,
HIGHTHRESHOLD_HB,
HIGHTHRESHOLD_LB,
SpeakerVolume,
HV_READING,
TARGET_HV_MSB,
TARGET_HV_LSB,
HV_CALIB,
SS1_0,
SS1_5 = SS1_0 + 5,
SS2_0,
SS2_5 = SS2_0 + 5,
SS3_0,
SS3_5 = SS3_0 + 5,
SS4_0,
SS4_5 = SS4_0 + 5,
ACCURACY_DISPLAY,
DOSE_ALARM_0,
DOSE_ALARM_1,
DOSE_ALARM_2,
DOSE_ALARM_3,
LANGUAGE,
CALIBRATION_CPM_MSB_0,
CALIBRATION_CPM_LSB_5 = CALIBRATION_CPM_MSB_0 + 23,
CALIBRATION_USV0_BYTE3,
CALIBRATION_USV5_BYTE0 = CALIBRATION_USV0_BYTE3 + 23,
DOSIMETER_UNIT,
ullix Posted - 04/23/2024 : 00:41:48
It is the same as GMC-500/+.
I'm afraid: No. Unless the 500 firmware also had a change.
Ihab17 has pointed out the most obvious difference, 6 calibration points instead of 3.
The 600 configuration in 2.52 is also different from the GMC-800 1.08, which also codes for 6 points.
Please, which are the current firmware versions for which counter? And what are they? And what are the first versions for the various counters, where this new coding applies?
ihab17 Posted - 04/23/2024 : 00:18:35
GMC 600+ Rev 2.52 has 6 calibration points (seen from the counter)
003541 CPM, 10 uSv/h
031870 CPM, 100 uSv/h
112584 CPM, 500 uSv/h
183243 CPM, 1000 uSv/h
228730 CPM, 2000 uSv/h
282307 CPM, 5000 uSv/h
Is this correct? Is this what GMC-500+ has?
wikilicious Posted - 04/22/2024 : 16:06:06
I really wish GQ would embrace GitHub...
It's a whole lot easier to browse revisions and file bugs/issues...
And most importantly, have a source of "truth"
EmfDev Posted - 04/22/2024 : 10:25:27
