 Might this be considered electronic harassment?
Dantheman Posted - 12/08/2021 : 18:04:27
Hello I have been receiving high cell tower readings. I reside by no cell tower and power line readings as high as 19.6 mG. What can cause power line readings, other than power lines? I covered the area with an approximate 12x12 piece of tinfoil. Please see jpeg. I have again started to also get hit with something in my front window. Not sure if I can post Youtube here, as I have uploaded the latest https://www.youtube.com/watch?v=nK07gWdhmTw, https://www.youtube.com/watch?v=xvszjD2DZks.
Breizh Posted - 01/31/2022 : 03:18:39
Have a look to stopeg.com
https://www.stopeg.com/home.htm?tid=1643627461
Let's all try to end Electronic Harassment / Electronic Torture in 2022! UPDATE
Havana Syndrome !
Breizh
Dantheman Posted - 12/17/2021 : 18:12:31
Hi Dantheman, power line readings can come from just the wirings inside the wall as long as the unit detect 50-60 Hz EMFs and EMF readings higher and not just under high voltage power lines. For the tin foil, not sure how this happens but we'll have to investigate more.
Thank you very much for your help here. There are also these that I posted back in 2018 https://www.youtube.com/watch?v=m6s0aDDx64s&t=68s, https://www.youtube.com/watch?v=V_13C8tldgU.
Dantheman Posted - 12/17/2021 : 18:09:26
EmfDev Posted - 12/09/2021 : 10:45:57
Dantheman Posted - 12/08/2021 : 18:09:48
These were the first videos I took in 2018 when this all started https://www.youtube.com/watch?v=xtPgDDskkys, https://www.youtube.com/watch?v=MkszhvrSUTU&t=513s. I am trying to upload images but I am having problems here.
