 Something seriously wrong with your ACPM algorithm
rodorr@comcast.net Posted - 04/06/2020 : 09:23:54
The running average is all over the place. My average has been rising over time which is fine and that issue appears to be correct but the problem is it doesn't index properly. For example my rate has been going something like this, 16.79 then goes to 16.89 instead of 16.80. Then when it got to 16.99 the next index went to 16.10 instead of 17.00. It's been doing this for a long time and I know others have had similar issues. Model GMC-500+, Revision 2.14.
Sincerely,
Robert Dorr
saltchiropractic Posted - 01/20/2021 : 21:37:25
great work! We were looking to make an app for we only made one for iOS and is not updated. Thanks for sharing!
EmfDev Posted - 04/09/2020 : 08:50:13
Hi Robert, sorry for the late reply. Grats! It is great that you figured it out! :D
rodorr@comcast.net Posted - 04/08/2020 : 13:30:38
Just never give up!! I got all of my errors cleared up and now everything is working properly!!. Sorry for all the correspondence.
Sincerely,
Robert Dorr
rodorr@comcast.net Posted - 04/08/2020 : 13:09:42
OK, well I dug a bit further and found the User ID and the Counter ID, but I'm getting an "Invalid Counter" message under "Test Connection". My wifi connection is good and I'm getting a valid IP address so I know I'm communicating with my router. Any ideas?
Thanks,
Robert Dorr
rodorr@comcast.net Posted - 04/08/2020 : 12:44:23
I figured it out. The baud rate was set to 57600. I set it to default 115200 and that did it. I wish I had know that it erased everything though. Where do I find the User ID and Counter ID. I didn't write them down and I have no idea where to find them.
rodorr@comcast.net Posted - 04/08/2020 : 11:56:34
Windows 8.1 Pro
EmfDev Posted - 04/07/2020 : 14:42:52
Yes that is correct. Which version of windows are you using?
rodorr@comcast.net Posted - 04/07/2020 : 12:54:29
I am unable to install the firmware update. My computer sees the USB port properly but when I run the update app, it says that it is unable to locate device. The serial number I gave you is the one that shows under the "Main Menu", "About", "Serial #". Is that the number you are looking for when you ask me for the serial number?
Sincerely,
Robert Dorr
EmfDev Posted - 04/07/2020 : 09:27:31
Email sent.
rodorr@comcast.net Posted - 04/07/2020 : 06:52:00
My average on my GMC-500+ is the same as what is shown on the web page. My serial number is xxxxxx.
Thanks,
Robert
EmfDev Posted - 04/06/2020 : 09:32:40
Can you please send me your serial number? There might be a newer firmware and might have fixed that problem.
EmfDev Posted - 04/06/2020 : 09:31:54
Hi Robert, does that ACPM appear the same as in the device?
rodorr@comcast.net Posted - 04/06/2020 : 09:29:59
I forgot to mention the ACPM I am referring to is the web page display ACPM column of Historical Data.
Sincerely,
Robert Dorr
