 GMC 320 Plus Charger needed
4AlwaysRt Posted - 08/18/2019 : 01:30:32
I have a GMC 320 Plus, the battery is dead and I can't find my charger. What specs do I need to look for in a replacement charger?
4AlwaysRt Posted - 08/18/2019 : 17:33:27
Originally posted by PKIDelirium
All you need is a USB to USB Mini-B cable. if you want to charge from a wall outlet, a generic USB to AC plug adapter for smartphones will work with the aforementioned cable.
Just to clarify, the port on the unit is USB MINI-B, not Micro.
Awesome thanks. That makes it easy. I was trying to figure out the round plugin. Being able to charge through the USB Mini-B takes the difficulty of it out.
PKIDelirium Posted - 08/18/2019 : 08:45:02
