 Hubitat Elevation Driver beta is available
cloudwizard Posted - 08/01/2021 : 15:44:50
Hi There,
Just wanted to share this driver I just created for the Hubitat Elevation Home Automation system. (https://hubitat.com/)
This driver uses the JSON for the latest reading of your device to populate the CPM, ACPM and uSV of a new virtual device within the Hubitat system that can be obtained here https://www.gmcmap.com/historyData-plain.asp?Param_ID=<YOUR GEIGER COUNTER ID>
To give it a try
1) Download the driver and install it in the same manner as any other hubitat driver
Its available here as a raw file to copy and paste into Hubitat
https://raw.githubusercontent.com/WBEVAN/gmcmapdata/master/gmcmap_device.groovy
2) Create a new virtual device using the new Driver (GMCMap driver)
3) Modify the Geiger counter ID to be that of your registered device
4) Set a preferred refresh rate for it (Default is 10 mins)
Sit back and enjoy the virtual device driver pulling the data and presenting it on your dashboards (I have only tried Sharptools.io ) and all of the fun automation you can do when CPM or uSv reach some hot limits.
Enjoy
Wayne
crudtrap Posted - 12/09/2021 : 04:05:23
i am using the hubitat dashboard app. it is not refreshing the data. i can manually refresh the virtual device, but to automatically. any advice appreciated. thanks
crudtrap Posted - 11/11/2021 : 03:37:15
excellent. thank you
