| T O P I C R E V I E W |
| user_amstelchen |
Posted - 07/11/2019 : 12:07:37 Proud new owner of a GMC 320 Plus v5 :-)
Didn't try WIFI yet, my GMC only supports password length up to 16 chars unfortunately. Is there any chance to get that sorted out in future firmware?
Using map and forum with https:// works better, I use the addon HTTPS Everywhere. Probably the webmaster could set set a redirect at the webserver to always force the use of HTTPS? Not sure if the geiger counter itself can send data over HTTPS though.
History is showing 'Date (GMT-7:00)' while the actual timestamp is GMT.
Resetting password for the site will set the password to '123456'. If not changed that is a bit insecure I think.
Also I found the website is sometimes very slow loading...
Sorry if this is a lot, just my thoughts. |
| 1 L A T E S T R E P L I E S (Newest First) |
| EmfDev |
Posted - 07/11/2019 : 13:59:52 Hi user_amsterchen, thank you for your feedback!
Unfortunately, there won't be any update for 320+ to increase password because it's limited by its CPU. I'm not sure if you can setup your WiFi so it can accept your unit without password.
We did put HTTPS before but it caused more problems that's why we left it out for now.
The GMC-7:00 will be removed in the future including the default password.
That's because the server is slow, we already did some modifications to make the website more responsive than before. |
