 Rad Lab - Geiger tube simulation
Gissio_ Posted - 11/27/2025 : 08:44:09
After reading much about what the correct sensitivities of various Geiger tubes are, I decided to tackle the problem on my own and wrote Rad Lab, which uses Monte-Carlo simulations to provide sensitivity values for various sources of gamma radiation:
https://github.com/Gissio/radlab
Check the .ipynb examples for the relevant results:
* https://github.com/Gissio/radlab/blob/main/examples/hh614/hh614.ipynb
* https://github.com/Gissio/radlab/blob/main/examples/j305/j305.ipynb
* https://github.com/Gissio/radlab/blob/main/examples/lnd-7317/lnd-7317.ipynb
* https://github.com/Gissio/radlab/blob/main/examples/m4011-j321/m4011.ipynb
* https://github.com/Gissio/radlab/blob/main/examples/sbm20/sbm20.ipynb
* https://github.com/Gissio/radlab/blob/main/examples/si3bg/si3bg.ipynb
The simulations seem to align quite well with reality.
For the detector geometries, I collected as much information as I could. You can find this information in the examples folder (specs and photos folders).
Here is what Rad Lab does:
1. Loads geometry
A geometry.toml file specifies:
* a Source box emitting parallel particles toward the detector at the coordinate origin. The source area equals the width × height of this box.
* an EffectiveVolume, inside which freed electrons are counted.
2. Runs Monte-Carlo transport
Particle transport is simulated using Calzone/Geant4.
3. Counts ionization electrons
Electrons with energies above 36.4 eV (the W-value for neon) produced in the EffectiveVolume are counted. Based on: P.A. Zyla et al., Prog. Theor. Exp. Phys., Particle Data Group, 2020.
4. Computes detector efficiency
Efficiency = detected electrons / incident particles.
5. Computes dose sensitivities
Ambient dose equivalent: using ICRP 74 data.
6. Generates emission spectra
* Isotopes: spectra from paceENSDF (IAEA ENSDF data).
* X-ray tubes: spectra from SpekPy.
* Natural background: modeled as a simple decaying exponential.
7. Computes equivalent effective dose for each source.
