 Question about RF Sensitivity
Stephan Posted - 04/11/2019 : 09:51:41
When the RF sensitivity of the EMF-390 is set from Standard to Sensitive, the measured value changes from 89 pw/cm2 to 610 nw/cm2. That's a big difference.
Which setting should be used to obtain a correct measurement?
Thank you very much.
Stephan
EmfDev Posted - 05/10/2019 : 15:02:25
The RF sensitivity filters low level noise. Affects AllInOne mode and Vertical mode RF. It's not a gain boost.
paul Posted - 05/10/2019 : 11:55:33
Which antennas does the RF Sensitivity function effect ?
I presumed only the 10 GHz.
But it does not seem to effect the RF Browser.
Is it a gain boost ?
EmfDev Posted - 04/12/2019 : 14:40:50
It's the same 1MHz - 10GHz.
Stephan Posted - 04/11/2019 : 23:51:01
For which frequency range is the Standard setting open?
Stephan
EmfDev Posted - 04/11/2019 : 11:48:10
The sensitive one is open to everything(1MHz-10GHz also possible to pick up noise). Use standard for more accurate data.
