 GMC-300E+ Flash Memory?
GOTO Posted - 04/05/2019 : 23:35:44
I use a GMC-300E+ Re3.25 Ser# 7e017a013467 here. The device loses the previously recorded data after switching off. A download of the data shows only one empty table. In other words, the flash memory is empty and total counts start counting from 0. Is there a firmware update or is this a hardware problem? Greetings Gottfried
GOTO Posted - 04/13/2019 : 12:51:17
Problem clarified:
John from support helped me a lot. One must switch off the save function before a data transfer, then it runs, as it should.
EmfDev Posted - 04/08/2019 : 08:28:11
Hi GOTO, did the history data downloaded previously work? You can email support@gqelectronicsllc.com to check for updates. Thanks!
