 GMC-320 Plus V5 - WiFi problem
LJ Posted - 01/26/2017 : 13:39:23
Hi, just got my unit yesterday, configured it and it was uploading data fine to gmcmap (h**p://www.gmcmap.com/GMHistoryExec.asp?param_ID=5033004996). Then the battery went flat (oops!) and having charged it up I can't get it to connect to WiFi again. It doesn't appear to be requesting an IP address from the DHCP server. The DHCP server is giving out addresses to other things fine. I've tried a factory reset and entering all the data again, but it always reports the IP address as 76.74.45.70, which just happens to be the ASCII codes for my SSID "LJ-F". Any suggestions how to get WiFi working again? Thanks!
17   L A T E S T    R E P L I E S    (Newest First)
ZLM Posted - 03/07/2017 : 07:39:50
Heartbeat stopped.. means the real time monitoring is stopped.
During the real-time monitoring, if other communication requested and need to use same comport, the real-time monitoring will stop.
So, the Heartbeat stopped.. is not a big issue here.
drewSI Posted - 03/07/2017 : 06:00:20
Now I am done until I hear from support.
drewSI Posted - 03/07/2017 : 05:59:32
The heartbeat issue seems to be only with setting not terminal It autodetects wrong port speed. IF I shut off autodect, and set it manually, it still switches to the wrong speed as if autodetect was on. Terminal works properly alone.
drewSI Posted - 03/07/2017 : 05:51:35
DCHP is enabled
AT+CWDHCP_CUR?
+CWDHCP_CUR:3
drewSI Posted - 03/07/2017 : 05:47:10
You cannot use AT command to search for or look specifically for the SSID, nothing gets returned because WIFI does not stay on unit.
drewSI Posted - 03/07/2017 : 05:42:39
SHows no access point
AT+CWJAP?
No AP
OK
drewSI Posted - 03/07/2017 : 05:33:48
WIFI mode is station mode.
drewSI Posted - 03/07/2017 : 05:32:19
I also have the ESP8266 AT INSTRUCTION SET manual which I am looking over, but I think I am wasting my time.
drewSI Posted - 03/07/2017 : 05:30:11
There are just upper case letters and numbers in the password. Nothing unusual. Not planning to change the password. I rather send the thing back. I really do not think it works.
drewSI Posted - 03/07/2017 : 05:25:47
When using the setting window and terminal, after a short time I get a heartbeat stopped error.
COM port 1 open failed.
COM port 2 open failed.
GMC-320Re 5.07 detected on comport 3.
COM3 opened successfully.
GMC-320Re 5.07
Heartbeat stopped..
Distelzombie Posted - 03/07/2017 : 04:09:39
Maybe you have characters in your password that are not compatible with the devices code page but you are still able to input them for some reason. I remember a similiar problem on a totally different device.
Could you try a simpler one?
drewSI Posted - 03/07/2017 : 04:02:34
I also did the AT commnad at the top of thread
AT +CWDHCP=1,1 and I get back
OK
WIFI DISCONNECT
I shut off unit and turn on. I turn WIFI ON, get the usual CONNECTING WIFI, then FAILED.
drewSI Posted - 03/07/2017 : 03:54:28
Yes. I read that whole thread. Thanks. Last night I did a factory reset and reconfigured this morning. Same thing. My SSID and password are correct. My SSID is only 5 characters.
I put in the SSID and password. Turned wifi on - failed. SHut off and turned on. Turned Wifi on- connection failed.
I get no wifi icon (though it seems it supposed to exist, it does not show in manual LCD screens).
Thus no IP address.
NO WIFI SIGNAL --- unknown
I did not screw with the router as based on the manual it should be working and I do not need more problems to solve.
I am contacting support as I give up at this point. I do not think the wifi chip is working and I am wasting time.
Distelzombie Posted - 03/07/2017 : 01:27:33
Hi drew. Have you read this thread? https://www.gqelectronicsllc.com/forum/topic.asp?TOPIC_ID=4384
drewSI Posted - 03/06/2017 : 16:23:39
I just rec'd my GMC-320+V5 from GQ directly and cannot get it to connect to my wifi. I first entered the SSID, then PW, then I go back to WIFI and turn it on and it fails. I get no signal (UNKNOWN) (even standing next to router). I have numerous wifi devices working well. The SSID and PW are correct. I am using VERIZON FIOS and their normal router and WPA2. Any ideas folks. I plan to check the router and restart it but I never had this issue before with phones, AMAZON fires, Apple Ipads, printers and laptops.
LJ Posted - 01/30/2017 : 10:53:20
Thanks, yes that fixed it.
ZLM Posted - 01/29/2017 : 15:08:39
The module seems lost configuration on DHCP. Send the DHCP enable command to WiFi module solved the problem.
104313 bytes
