 Blocking illegally Emitted Frequensies
jdx74 Posted - 05/16/2019 : 07:37:59
After identifying a microwave band of frequencies being illegally emitted from a Rife machine located in a neighbors's house, I need to block or scramble 2.450 GHZ to 2.457 GHZ. The GQ 390 shows those frequencies are being emitted at intensities up to 5 nW 24 hours a day. It's causing me a stiff neck and headaches (among other symptoms) every day. I understand that the Rife machine and/or the house its in is ungrounded allowing broadcast to a large area outside its location. Can a jammer be used to block or scramble those frequencies? Any other suggestions?
paul Posted - 05/17/2019 : 03:34:19
Here are a couple of very interesting pages of Rife Frequencies.
At first glance,there is nothing higher than 3.3Mhz and that
was the carrier.Most effective frequencies are very low.
h//p://www.rifevideos.com/dr_rifes_true_original_frequencies.html
h//p://www.royalrife.com/freq.html
EmfDev Posted - 05/16/2019 : 10:34:33
If you're sure it's not just wifi, try to shield 1 side of your house with grounded aluminum foil?
paul Posted - 05/16/2019 : 10:00:35
Most Jammers work by transmitting the same frequency as the
signal you wish to block,so not much help,demodulated at least.
Looks like wifi no ?
and how do you unground a house ?
EmfDev Posted - 05/16/2019 : 08:27:33
Hi jdx74, are you certain that the signal is coming from your neighbor's? Have you done more testing? Like go elsewhere were you can't detect that signal?
